vcLayout
vcLayout represents simulation layout object, which may contain vcComponent and other vcLayouts.
Parent: vcNode
Children: vcWorld
Referenced by: vcLayoutVisualization.Layout, vcWorld.Layouts
| Behaviors | list | R | Behaviors in layouts are not supported. Returns: An empty list. |
| ChildLayouts | vcList[vcLayout] | R | Gets the direct child layouts of this layout. |
| ParentLayout | vcLayout | R | Gets the parent layout of this layout, if any. |
| Visualization | vcLayoutVisualization | R | Gets the layout specific visualization settings. |
| clone | vcLayout | Optional Keyword[parent = vcLayout] | Creates a clone of sub-layout and its children structure in 3D world, and then returns the new sub-layout.See moreParameters: parent (vcLayout): Parameter is the parent sub-layout to be set to the new clone. If this parameter is empty, it will use the parent of the current cloning source, meaning that the source and clone will have the same parent. Returns: vcLayout: The cloned vcLayout situated at the new parent. Exceptions:' ValueError: When the layouts are the same. RuntimeError: Cloning of a sub-layout is not allowed when there is a hierarchy lock in the node tree, which happens during layout loading, or while moving a node from one place to another. RuntimeError: When there is no license for Layouts. |
| createBehavior | None | None | Layouts don't support behaviors. Exceptions: RuntimeError: Always. |
| createBehavior | None | None | - |
| createLayout | vcLayout | String name | Creates a new empty simulation layout under this node (vcLayout or a class inheriting vcLayout).See moreParameters: Name of the layout instance. Returns: The created layout node. RuntimeError: When there is no license for Layouts. |
| delete | None | None | Deletes layout node.See moreExceptions: RuntimeError: When there is no license for Modeling API. RuntimeError: When there is no license for Layouts. |
| getFeature | None | None | Features directly on a layout are not supported. Returns: None. |
| moveChildrenFrom | None | vcLayout source, Boolean globalpos | Moves all nodes inherited from vcNode (including vcLayouts) under one layout to another.See moreParameters: source (vcLayout): Moves the source layout’s children to this layout. globalPos (bool): If true or not set, the method overwrites the children’s relational / in reference transform with a new transform, which leaves them to their current global position. If set to false, their local transform is left untouched and their position changes accordingly to the new parent. Exceptions: RuntimeError: When either of the layouts are hierarchy locked. RuntimeError: When there is no license for Layouts. |
